raul_ghiran
Member
- Joined
- Jan 18, 2020
- Messages
- 10
gyraf said:Anything of ECC82/12AU7/5814 family produced before 1990
No, not at all
Thank you!
No, not at all
TillM said:Finished my second Unit.
For this build I use a red frontpanel and OEP transformer IN and OUT.
Could not make a comparison with the Lundahls but the bass DI sounds a bit different in my opinion.
Now I’ll take a build break![]()
raul_ghiran said:Hi! Where have you made the front panels?
Hi! The voltage before regulator is 17.5v. Another thing that might be weird is, on the C14 cap voltage is about 296-300v and on C15 240v straight. Is that Ok?volker said:What is the DC voltage before the regulator?
Have a look at the schematic. There is a reason, the 1st transformer has dual secondaries. For this build you for usual want two 30VA 110+110VAC:15+15VAC or :12+12VAC transformers (and not a single secondary 18VAC heat generator, partly shorting out BR2).mcrouch said:... Transformers are 2* 120v primary: 18v secondary.
...so filling in a location in your profile might be useful. Not only mains voltages differ between countries/continents...mcrouch said:My language was misleading,
As previously said, dual 18VAC secondaries wasn't called for and will be a heat generator.I have two transformers (30va) with 2*120:2*18.
Also, i am testing without a load on the output, could this be the issue?
