TillM
Check your wiring from the power transformer, I got smoked diodes, when I misswired the power transformer in one build.
Your transformer is fine. Without load the AC voltage is higher.
The problem is somewhere in your build. Smoking rectifier diodes is sign for a very low resistance betwen HT and Ground, probably a dead short.
It is pretty hard to help you from the distance. Check your build again and show some photos of it.
What is this blue thing under the HT PCB? A choke or a temporary spacer?
I would check the wiring.
Especially from the small psu board to the main board.
From the first look it seams wrong.
make sure there is good continuity between all enclosure parts and ground
Can you sketch your HT power supply?
Which diodes do you use? Type?
innercityman said:Sketch ? What do you mean ? I used the spare psu board that I finally find out.
I think your smoking diodes come from the current flowing into the gigantic capacitors at the moment of switch-on. That's why the problem disappears when you switch on again after the device has already been switched on once - the capacitors are then still charged, the inrush current flow is lower,
innercityman said:Very interesting... This is probably the explanation. So these caps could be faulty or maybe two big ? What would be the solution... Replace them with smaller ones ?
The caps are ok, just to big for this setup. You can test it, disconnect one of them.
You can fix it with smaller caps or more resistance, so that the inrush current is limited.
rock soderstrom said:We need more detail, a schematic! I can not see whats going on on the HT PCB.
Is there a resistor betwen the two 470uf capacitors? Like R1 in the attached schematic? If so, what value?
