Clbraddock
Still no reply. Guess I can initiate a charge back and build something else.
Thank you! It even says “to light 12v 50mA” on the PCB.Perhaps 12V/ 50 to 150mA lamp off the heater voltage? That's what I do..
Thank you for the answer. I didn't go through the 118 pages...yet. I suppose I will...yes, those housings should have been soldered to the base plate under the transformers. I'm sure we talked about this many times before in this thread..
/Jakob E.
It seems it's not in this thread.Thank you for the answer. I didn't go through the 118 pages...yet. I suppose I will.
Heh..just run a wire from ground point to the screening can. The can solders quite easily. Don't ask how I know![]()
I've done that, redoing the grounding, twisted all the AC power cables and shortcut the instrument input (I don't need it). Now, I don't have anymore the heavy rumble noise...just run a wire from ground point to the screening can. The can solders quite easily. Don't ask how I know![]()
