Hi everybody, and my best wishes for a great 2023.
I finally completed my G9 unit. Things were a little bit weird when i built the unit, about 10 years ago. A lot of noise, crackling and hum, expecially on channel 2. But i decided to open the unit once more and have the final battle with it. So just to say what i have done to accomplish the mission.
- i desoldered OEP's from the board: the plates were unstable because the first soldering points were broken. So i soldered the plates to their screens all around. And soldered again to the board.
- replaced all signal caps and two electrolytics caps of the second channel
- replaced channel 2 tubes (both 12au7)
- replaced the C14-C15 220 uF 350V with 470uF 450V.
- cut GND from/to xlrs except one and rewired to star ground accordingly.
- installed a metal plate to segregate the 220 trafos and power switch wires.
- moved the power switch to the right (as the original Gyraf design) instead of the center of the front panel. Of course i had to make another front panel with my CNC (first time i engraved aluminium, so im very proud of it).
The unit now is very quiet. Low noise, transparent, powerful and rich.
There is a 100Hz hum @ -81dBFS (mics connected, output at zero) which is acceptable. I suppose that to get rid of it i need to move the PSU outside of the main board (?). Maybe a job for the future. For now i can live with it because nobody would notice.
Here two pics of my G9 (alongside with my Gyraf-based SSL diy buss compressor).
I thank everybody in this group since every post in this long thread is invaluable.
My compliments to Gyraf. I also noticed that his boutique units are now on sale on Thomann![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
