It's DONE!!
I finally got up the nerve to fire up my G9. I plugged it in, flipped the switch, and immediately the fuse blew. :?
After a bit of head scratching and rechecking my work, I found the problem. Next to the main PCB I put a small two position solder terminal strip to facilitate the wiring for the main power transformers. It appears that I failed to notice that one of the terminals was same piece of metal that formed the mounting bracket for the strip. So I was basically connecting one side of the transformer's secondary to the chassis. Talk about an "Amateur Hour" mistake!
I cut all the wires loose, soldered them together without the terminal strip (covering the joints with wire nuts), and prayed that I hadn't cooked the transformer.
Flip the switch. IT'S ALIVE!! :grin:
I let it burn in for a few minutes and then started checking supply rails. The 245V rail was showing 235V. I assume this is within tolerance. The 12V rail was showing 11.72V, and the 48V rail was showing 49.2V. After letting it idle for a while, I connected a tone generator to the left input and a small powered speaker to the output. Good tone. Exercised the controls. All good. Switched everything to the right channel. No audio. :?
Careful examination of the right channel control PCB revealed the problem. I had neglected to solder the center pins for the "phase" switch, so no audio was passing through it. Another "Amateur Hour" mistake.
A quick touch-up with the soldering iron, and the right channel is in business.
Tried it with a Shure SM-58 just to make sure it worked, then with an Audio Technica AT4040(?) to check the phantom power. I also connected the tone generator via the instrument inputs. All is well! No hum, no oscillations, no weird noises, no smoke.
So it looks like I'm the latest proud new owner of a Gyraf G9 tube mic preamp!
A HUGE "TAK" to Jakob and all the rest at Gyraf. Thanks to all the guys here on the forum for your help as well. I'd also like to thank the Academy.... (Oops! Wrong speech!)
I can't wait to put this thing in action.
:guinness:
