caseyc said:BUT, ok i have read this thread and cant access oscillation problem thread for some reason....but on the the three last gain settings it both channels it totally goes too high...
I've been trouble shooting a similar problem but I have high freq osc only on the right channel (closest to the PT) with the last 3 gain settings...I would imagine this the same issue that needs traces cut but only on problem channel?
Edit: I'll answer my own question and say yes, the DI mod helps tremendously.
I just performed the mod and it ended any HF oscillations in the furthest gain settings.
Also, I've been researching ground schemes for the G9 design and have found that there are many seemingly successful grounding schemes - pin1 inputs strapped, inputs and outputs strapped, 1 input strapped directly to IEC, starground to chassis : which is the best?
Heres mine BTW, and other than the oscillation, its pretty quiet..:
Edit: I think I'm going to pull the output grounds and just tie input and IECplug to a star ground at chassis.The pres are pretty quiet untill they are full out then have just a trace of crackling and hum. I'm trying for ultra-quiet..
