g9builder said:
I think i may have the same problem as graph. A faulty TL783. My wiring was right and to double check this I wired the 48v up and got the correct result. Then the heater 12v and got the correct result. I then checked i was getting 220v from the last pair of secondaries and I am. Once connected to the board R34 smoked again straight away. I have checked all the diodes and resisters and they are all correct and placed correctly. I have also checked all solder joints and traces.
I therefore think that the problem must be with Tl783? Would you tend to agree with this? I have been unable to test tl783 because as soon as I turn on the unit R34 takes the hit.
Regards
TL783 is difficult to destroy. It has inbuilt short circuit and thermal protection. It's not expensive to replace though. On the other hand, you are irreplaceable, so be careful.
One tip that I read elsewhere and found useful was to wire up a 60W bulb in
series with your mains supply. If your g9 is sucking too much power, the bulb will light thus limiting the current to less than 250mA and hopefully protect whatever is causing the problem. Otherwise if all is OK it will glow momentarily (1/2 second or so) and then go out.
I personally would not have thought R34 could be damaged easily. A 100K 2W resistor would not burn out even if it had a full 400V across it (v^2/r = 1.6 watt). R37, perhaps, r33 also. But R34?
Obvious questions. Did you check the values of your resistors with a multimeter before inserting them in the board? It's relatively easy to make mistakes with (modern) 4 and 5 band colour coding schemes.
Suggest taking things step by step from the transformers onwards.
Four potential checks:
1. Remove the TL783. Check that the bridge rectifier is working correctly and that you are getting HT DC out of it at the top of C14. Even without the TL783 in place, C14 / R33 will smooth pretty effectively under no load conditions. You should be seeing more than around 280V DC here.
2. If that is OK, reinsert the TL783. There's a jumper marked "HT" right next to the TL783. Have you tried powering up with both the 'ht' jumper and c15 removed? Then there's virtually nothing that can draw current on the TL783 side of the circuit. So at least that would point you which side to look. If that's still a problem look very carefully for shorts around the TL783 and double check the orientation of the TL783.
3. Also check c15 is still acting as a capacitor and is not short and that it was connected the right way around (it is an electrolytic and polarity sensitive). If that checks OK then reinsert C15 and test again.
4. If that's OK then try removing the valves and then reinserting the "HT" jumper. Again there should be nothing that draws significant HT current.
The HT supply in all cases should power up at somewhere more than 240V DC (I found that the TL783 doesn't actually regulate the voltage very well until it has quite a load on it)
Of course, be very careful to properly discharge the HT capacitors C14 & C15 using say a 10-100K 2W resistor and check the DC voltage on them with a meter before handling them or any other part of the board at all [I actually permanently soldered a 1Meg bleeder resistor across them so that at least they'd always discharge themselves after a few minutes even if I forgot, so have a cup of tea after every test and take it easy].
