Studio Mollan
- Joined
- Oct 26, 2011
- Messages
- 326
MeToo2 said:When I built an off-board PSU, I measured inter-channel cross talk at ~-70dB down between 2 channels on one board (L input terminated with 200 Ohm no input, R channel 1KHz tone +4dBU output = -66dBU 1Khz output on "quiet" L channel) So I wouldn't worry about that if you're running L+R for a stereo pair of mics: you're going to get way more in-room acoustic bleed than that. Really not sure how much money you're going to save with an out of box PSU (or an inter-connect between 2 boxes) by the time you buy some high quality high voltage connectors (like 7 pin C091 Tuchels) and multi-core cableStudio Mollan said:Ok thanks for your reply!
So to reduce cross talk there should be separate regulation on each PCB. Is there not already cross talk between the two channels on the main PCB? When you say basic R-C filtering do you mean an extra filter or to move the filtering, or some of it, from the PCB to the external PSU box?
Emil
So you built one psu like the one on the main pcb and connected it directly to the audio circuits as in the schematics. Psu like the psu schematics but larger transformers. Eq pcbs as is but without any of the psu components?
I'm probably not going to use connectors from the psu. I'll hardwire it instead.
These preamps are a bit of a electronics training for me so I wouldn't mind saving some cash if needed. I bought 8kg of nos vintage caps and almost as much resistors also nos which I'd like to start experimenting with.
Emil
