leanlowkey
Active member
im sure im missing it. but where can I get a faceplate done at? thanks
I would replace the V2 tube socket if everything else has been checked.I've 100x checked that the components around the tube are correct, that there is continuity where the should be, that there are no shorts. I have also tried swapping tubes, swapping output transformers, swapping control pcbs. Nothing makes a difference. Cathode voltage drops are roughly the same between channel one and two. Plate Voltages are are also the same.
Beautiful work!Here is my single channel version of the preamp I made a few years ago. I changed some things like the power circuit and some other things. I replaced 3 custom toroidal transformers before I found the quietest one. ECC82 Input Tube, E88CC Output Tube, Lundahl LL1538 Input Transformer, Carnhill Output Transformer. The preamp is extremely quiet and sounds great. I intended to make 2 of them, but I never finished the second one, I have many hobbies and music and electronics have already been displaced by other hobbies
thanks that seems to be the issue. when swapping tubes I have to readjust the levels to make them even so I ordered some tubes. thanks again!have you tried swapping the tubes to see if it's about those?
