emrr said:
PM660 input impedance is 1800 ohms. It's defined by the 30K attenuator. If you have a 10K:600 in front of that (between your other comp and the PM660), then your other comp is seeing roughly 30K as it's load. You should not see any loss because of that, unless you are using a single 12AX7 (or similar) as a line output stage. I think you have another problem.
(30K actual) 10K:600 / 600:10K / 30K attenuator
If you are seeing 7 dB loss, you could say that your other comp has an output impedance of 30K (6dB power matching loss), and the other 1 dB is accounted for by the quoted transmission loss of the Edcors.
Consider it again backwards:
30K attenuator driven by 10K:600 driven by 600:10K = 30K load presented to source.
The 10K:600 / 600:10K cancel one another, minus transmission losses.
The 10K:600 in between units only helps to lower the output Z of the source device; also meaning it eases the load on the source device.
or:
30K attenuator connected to 10K:600. 30K is 3x10K spec. So the reflected impedance is likewise 3x600=1800.
A matched load causes a 6 dB loss. Drive the PM with a 1800 ohm source Z, and there will be a 6 dB loss. In the case described, using a 10k:600 between device and PM, it would require a 30K source Z to see a 6 dB loss. To ignore math, and go with gut and observation, even a 600 ohm source driving an 1800 ohm load should only see a tiny loss; a dB or so.
Any self respecting piece of reasonably modern pro equipment will have an output impedance of under 200 ohms; even the majority of tube preamps with 600 ohm ratings. This is due to application of negative feedback in the vast majority of circuit types. Many times the defining source Z comes from build-out resistances within the output stage, applied to prevent short circuit conditions. Many devices will have output impedances well under 100 ohms. So, very few things will struggle significantly driving an 1800 ohm load.
As stated a billion times in a billion threads, rated transformer Z's suggest the inductance spec, which varies depending on the target Z's the transformer is designed to mate. So long as you drive with a source equal to, or lower than, you will meet frequency spec. That's the simple version.
