I used my poorman for recording a guitar track recently. It's been in my studio rack for 18mths or so, no probs. 8)
guitar -> valve pre -> vca compressor -> poorman limiter (fast time constant) -> daw
Was very happy indeed. The poorman limiter added a whole truck load of charasma.
Apart from the simple modification of the time constant network, I don't see so much wrong at all with the design or the implementation, considering it is targeted at the 'diy' community.
I would probably recommend for the less adventurous persons, to make a pair of 'one channel in one box' units
This would avoid reported issues relating to power transformer capacity (heater supply), heat buildup, inter-channel interactions, overall wiring messiness and so on.
The PPA mods to the psu pcb worked well for me too and I'd recommend them for improved psu pcb 'mean time between failures'
That would leave basically just tube matching and wiring of the 2x dual switched attenuators as the main challenges.
Some patience and care goes a long way here. Tube matching is the main determinant of 'audio quality' imho.
Meaning 'buy lots' and 'try lots' of tubes.
Beyond that, I would use some shielded transformers - probably trial and error to find some that would be 'better' than the specified edcors. That and a toroidal psu transformer if possible. And wait until testing to find the quietest location for the signal/control transformers (in addition to the usual toroid rotation to find quiet spot).
Makes for a markedly quiet unit. If the basic thing isn't working, you're doing some thing(s) wrong!
Do I think it deserves a 'Mk II' revision?
Sure do!
Maybe something in the way of a 'drip' treatment to make it really easy.
A little less cramped on the psu pcb, maybe with one pcb for the whole single channel and possibly sowter traffos onboard.
Sound familiar? A 'poorman' no more
I found the poorman 'sound' desirable enough to go to the next level, inspired by Analag/SilentArts, Lolo and DaveP, not to mention CJ, PRR, EMRR and a number of notable others. Should be done in another year or so ;D
One thing I say - in cold weather, the poorman 670 makes a welcome heater. Serious!
PS - for 'mastering', I don't think of the poorman 670. I use a TC Finalizer!
PPS - one thing I'd *really* like to see - an Analag/Silent Arts 'channel strip' using this configuration.
That would 'rawk'. In a 3Ru. None of this little 500 series stuff
