[silent:arts]
a copy is already on its way
dagoose said:Just wondering, if you would upgrade the input iron, what would you choose? The edcors are OK, but i'm not 100% satisfied with OK.
I'd like the sound of lundahls myself but like to try something else for a change..
anyone?
anyone?
I like the distortion indeed but there is something really subtle going on in the lowend that i don't like and i think it will be solved with different tranny's. I had the same thing with my d-aoc, edcors lacked some tightness in the low-end and that was totally different with lundahls on the input. It opened up the sound completely the way the edcors could not. Going to check the ll1676, always like the sound of lundahlsradiance said:dagoose said:Just wondering, if you would upgrade the input iron, what would you choose? The edcors are OK, but i'm not 100% satisfied with OK.
anyone?
Kingston got great results with the Lundahl LL1676. You say you don't like the sound but maybe it's the "Lack off" sound?
I don't see any reason to make my poorman cleaner by adding Lundahls...the whole reason for building this was added distortion![]()
dagoose said:Going to check the ll1676, always like the sound of lundahls![]()
wow... 125 euro for 1..radiance said:dagoose said:Going to check the ll1676, always like the sound of lundahls![]()
Let me know when you're buying these...& if you've found a cheap source...man these ARE expensive:-(
dagoose said:wow... 125 euro for 1..radiance said:dagoose said:Going to check the ll1676, always like the sound of lundahls![]()
Let me know when you're buying these...& if you've found a cheap source...man these ARE expensive:-(![]()
Kingston said:Who says you have to run the input 1:4? All it does is artificially limit input impedance to 600 ohms and give you 12dB of gain you do not need. Input attenuator is right after the transformer so gain staging is a non-issue. Just give it a bit higher input signal with lesser ratios.
There are plenty of other very high quality options 1:2 and especially 1:1.
I run my PM660 with custom 1:3 input tx and it works like a charm without any attenuator modradiance said:Kingston said:Who says you have to run the input 1:4? All it does is artificially limit input impedance to 600 ohms and give you 12dB of gain you do not need. Input attenuator is right after the transformer so gain staging is a non-issue. Just give it a bit higher input signal with lesser ratios.
Yes, but does that mean you'll have to rethink the attenuator resistance value to still have a sensible range?
Cause there's no way I'm going to redo those Elma's ..
