The meter trim pot idea is indeed very nice :guinness:
Also the XLR to bypass board (if not using neutrik) idea rocks :guinness: :guinness:
Impressive build :thumb:
Bernd, did you use Log on the Threshold switch too?
With the Uraltone switches - i had good results with a small piece of those plastic restraints that you use for holding your wires together. it bends right into the slit in the switch and works wonderfull as a stoper.(just get the small ones and cut to legnth)
