Knarleybass
- Joined
- Jul 7, 2006
- Messages
- 130
well, still making slow progress on my PM660, turns out the LM337 is getting so hot it's shutting down, could there be something wrong or do I need a larger heat sink?
Noting wrong, voltage depends on mains transformer U use. Ok, you have 370V unregulated, than the base of Q1 will have 368V, emitter something like 369V and you forget that collector is not grounded but biased at 254V. So "wrong" is that Q1 never "see" ground , just difference between base and collector. No need for measuring it's clear by analyzing the schematicsExcuse me Moby,
I'm talkin about MPS92....... =Q1
is impossible to have 300V there !!!!
SO form trafo i have 270Volt AC in .
Then after D1-2-3-4 i will find near 370 and then at base of Q1 i will have near 370.
Whats wrong Huh
Somethin' is wrong for sure, check did you reversed something.Knarleybass said:well, still making slow progress on my PM660, turns out the LM337 is getting so hot it's shutting down, could there be something wrong or do I need a larger heat sink?
Great news Check the -17V regulator, if you are talking about voltages on RV6AW_music said:Hi, REPORTAGE FROM THE FRONT LINE !!!
Great progress with the BEast !!! ;D
Finally Getting ready with the PSU!
There were a couple of resistors with wrong values!!! ....AZZ.....
So with board attached now i have :
245V , 137V, 5,8V Heater
Finally It seems OK !
NOW
I tried to set the trimmers but the value goes from -0,2 to -0,78 !!!!
I cannot set them to -4,5 and -2,4
What should i have check ???
regards
Yes, it's vexing but that's the part of DIYKnarleybass said:everything seems right, nothing reversed, at least everything follows the silkscreen on the PCB, it's Vexing...
this depends very much on the ballistic of the meter you used.AW_music said:The meters react very slowly....... in this the way they are supposed to work ????
skal1 said:need some help on the meter light connection and bypass boards ,
can they both run of the 17 v rail
Do i connect the light and relay boards in parallel with the 17 v rail
U welcome, cheers!Thanks to Silent.art, analag, moby, and mata_haze for help and support !!! NEVER GIVEUP! NO WAY!
Moby said:U welcome, cheers!Thanks to Silent.art, analag, moby, and mata_haze for help and support !!! NEVER GIVEUP! NO WAY!
Yes with this box it's pretty tight ;DAW_music said:I'm wondering where i can put LOLO's pcb ???
Than check the components on PM660. Must be that something is shorting. Did you tried to adjust the RV6? Is the resistance of the RV6 not less than 2k5?Knarleybass said:well,
turns out the -17v supply is working properly, at least when it's not connected to the PM660 PCB, when it's connected the LM337 gets so hot it shuts down.
