Thanks Volker.
Well. it's a new day with a fresh head.
I tested ALL my tubes & they measure good.
The Power TX does get VERY hot but it takes about a half hour to get there... any ideas on this or should I worry about it?
I broke out my scope to check the audio path & it looks pretty good & it's compressing.
This was VERY interesting to be able to "See" the release times on the scope!!!
I have a switch set up for six settings:
1) 2u + 68k
2) 2u + 180k
3) 2u + 470k
4) 2u + open
5) Blank
6) STOCK - 10u
Since the stock setup goes thru the 10u First, Then thru the 10k POT... I decided to leave the pot in that position & be able to use it with ALL the setting for an added effect. It's pretty cool.
In "Stock" mod, the release is VERY SLOW!!!!!!!!
(anyone else notice this??? )
I like the "Blue Bird" values of 2u + 68k but adding the other values are very useful.
I also think the Distortion I'm hearing (only when compressing) is like Bluebird described... I may try the tube change too.
OK, what I notice on the scope is that, as SOON as the threshold is kicked on the 1st setting (mine is set up LOG Taper) it knocks off aprox .6 volt! This seems like a LOT to me. Yes my pot is set up correctly (measured & double checked)
This is where a "DC Threshold" would be useful.
Any ideas on how to back this down?
Last update,
My meters are still reacting very strange... like a magnetic field.
What should I do about this???
Maybe use shielded cable on the VU send & return lines?
What's also strange is each meter seems to react to the opposite channels threshold (channels Un-Linked)
Time to take it off the bench & re-listen.
