Error in my 1073 simulation?
GreyboxAudio
Germany
Hey,
I tried to simulate a 1073 with BA283/BA284 amps but something seems to be wrong. With each amplifier stage there's a massive drop above 200Hz until my output signal reaches -200dB at 20kHz. If anyone with a better understanding of the 1073 could help me find the source of my mistake, that would be awesome <3 I've attached the simulation.
  • 1073_discrete.zip
    4.4 KB
The output stage (bottom right) has no load (in the collector of Q12) - you've drawn the transformer as just a wire, so it's not there, so you'll get diddly-squat on the final output (you'll just be connecting the power rail to ground or not, depending on the polarity of the signal).
R16-C13 node missing connection to Q5 base; same with R5-C5 and Q2 base.
Good catch, thanks! Unfortunately the two BA284 stages still drop about 60dB each at 20kHz. I only drew in the output amplifier to see if it is maybe required to get a linear frequency response. But I don't think that's the case, so we can probably ignore it for now.
Are C3 and C6 really supposed to be 470nF? I know it says "470" in the original schematics, without "p" as the 47p's above them, but... It makes no sense for such a large value to be there, which would explain the low-pass effect.
Must be some sort of typo, either a zero instead of "p", or just missed adding the "p". All other capacitors, even nF-range ones do have the suffix added, so...
Corresponding caps on the other "pieces" of the BA284 seem to be 1.5nF, so there you go - 470p makes all the sense, and explains the symptoms you're encountering.
Awesome! I was assuming nF as implied because only pF & uF were mentioned explicitely. I've changed C3/C6 to 470p and C7/C14 to 680p and this looks a lot more like a 1073 now:
about the output stage: there should be an unbalanced output available there (point F on the original BA283). Would the correct transformer loading still matter in that case? I was assuming it's not important, which is why I've drawn the transformer winding as a wire.
Well, as i said, without a collector load there, there will be nothing for the current flow to develop a voltage drop over (except that series 12 ohm in the supply line).
Why don't you do a transient simulation and see how the waveform looks without a transformer?
Making a basic transformer in LTspice is also easy. Place two inductors, called say L1 and L2, then and add a SPICE statement K1 L1 L2 1.
K is a transfomer, L are the two inductances, their value ratio makes the voltage transformation, the "1" at the very end is the coupling efficiency, 1 is 100%.
Also use some actual partnumbers for those BJT's, the default models are suspect, maybe IC models.
Use a realistic impedance for the power supply. It is never 0 ohms.
Like it was said before, use the transient sim to see that the circuit actually works.
Making a more realistic transformer is more complicated that includes parasitics and magnetic metal properties.
