JW
Okay, back again. Pulsing is persisting, even after making sure 1K is the first resistor (like the most recent schematic in PRR's last post. ) My cap value is 1uF. How low can I go with capacitance?
abbey road d enfer said:The cap can be anything from 1 to 10 uF, so it may be film cap or a lytic; in the latter case you must connect the positive side to the diode's cathode.
Just try it. The worst that can happen is the capacitor voltage falls below the neon extinguishing voltage so it turns on and off at 60Hz, basically the same problem as when powered by AC.JW said:Sorry to bump this one again. Can the cap be lower than 1uF? Suggestion earlier was to lower cap value to treat the pulsing problem. I'm already at 1uF
