pucho812
O.k. so had a buddy just pick up a brand new shiny S3 control surface for his pro tools system. Long story short there was a bunch of soft to instal and a a bunch of things that had to be done via their website. In the end there was a software separate from pro tools for the mixer, that runs at the same time as pro tools. The software controls the mixer and allows it to work. So after much monkeying around He called me because it was not showing up and not working. After 20 minutes with it I found the problem.
A big ol catch 22. Needs a firmware update to work with the software versions installed. In order to firmware update software needs to see the controller. Software will not see the hardware with shipped firmware. So your stuck as you can't do anything without the software seeing it first which won't happen without a firmware update.
Avid : A Very intermittent Device
