Fine... I'll bite.
Sure, notes are frequencies. -But they're EXACT frequencies. -There's *ZERO* 'spread' in a sustained note. You have to have THAT frequency. -Even teeny errors in frequency are catastrophic.
EQ's -on the other hand- may have 4 bands or so. -What are your favourite four notes then? What happens if you have a key change? -Modulate up a whole-step... do you have to get the board rebuilt for the second half of the tune?
And what if your notes are in the fourth octave? -What happens if the overdub you're EQ'ing strays into the next octave up or down? -"Can we bring up the 'D' a little?" -'No'. -"I thought we had a 'D' control?" -'Yes we do, but that's D4... you played a D5'...."
-Unless of course you want an 97-band EQ to match all the keys on a concert piano, in which case it all makes PERFECT sense...
I'm sorry, but making the equation that "EQ's have frequencies and notes are frequencies, so this makes sense" is so over-simplified that it's just absurd.
If you want to label EQ's with "notes" instead of frequencies, that's very cute. -But ultimately useless.
-And I've never CARED what the frequency is... -I just know it's too-high, too-low or just about right. -I've basically never looked at the number. -When I'm adjusting things by ear, I just don't care what the exact frequency is, and I doubt I ever will. -The idea of knowing what step on a 12-step repeating logarithmic frame is, is simply futile, and serves no purpose.
Even if I were to make the ludicrous over-simplification that 'center-frequencies equal notes' is significant in ANY way, then when I boost an EQ band, can I then hear one note getting louder? -No. -And I never will. I'll NEVER use bandwidths that narrow. -Even if I notch frequencies out, do I care what note note is? -No. Do I even care what FREQUENCY it is? -No. -And I never will. -I just know that it's a drum ring/feedback 'zing'/acoustic resonance/whatever that I want to tame.
Cute, but pointless. And -according to what Abbey Road says- likely apocryphal.
I even note that the original post is effectively "hearing this from someone who heard it from someone else who worked with Ray".
