- Joined
- Feb 3, 2012
- Messages
- 73
EMRR, here are the notes from the tech who has the unit on his bench. As I mentioned, this is beyond my ability.
You were right on the money here.
His response...
I've asked him to repopulate the entire pcb. To basically rebuild it. Is there anything particular NOT to change on the pcb?
Attached is a pic of the full pcb.
Upon investigation, approximately 60% of all electrolytic capacitors were observed to be physically leaking electrolytic solution. One even has a significant crack and bulge in top surface. Approximately 6 resistors are observed to be hyper-sensitive to temperature and vibration (tested w/ cold spray and soldering iron). Input transistor (Q1) is observed to be intermittent and noisy. Excessive leakage was found upon testing. |
His response...
Full recap of all electrolytic capacitors on the PCB. Replacement of all noisy resistors. Replacement of Q1 with a suitable low-noise, germanium device. |
