leadbreath
Seriously doubt anyone will voluntarily apply a megger to their nutsack, but in this day and age you never know!!??
Not through, upon. That is a huge difference.Nic Tesla was able to safely demonstrate hundreds or thousands of volts passing through his body , the trick was he never allowed the current a path across his chest .
Én is így gondolom, 50 év tapasztalata alapján. De ezt tanították a technikumban és az egyetemen is. A 12 voltos feszültségről üzemelő A osztályú erősítő (Motorola 15J04) mérésénél viszont a BNC csatlakozó 900 MHz-es frekvencián megégette az ujjam!A 120V DC-t semmiképpen sem tartanám "elégséges" módon biztonságosnak - tényleg nem értem, honnan veszik ezt az adatot?
Nálunk az LVD biztonságos részét hagyományosan 48 VDC-nél határozták meg, ezért a fantomtápot és a telefonokat ilyen módon látják el.
/Jakob E.
Akit mostanában elég erősen lecsapott a +118V
Csak nagyfrekvenciás árammal mutatta meg, ami nem nagyon hatol be az emberi szervezetbeNem keresztül, rá. Ez óriási különbség.
When I was young, in the 70s, I was hit by a TV set "booster voltare" 800 Volts. I still remember it today!The police in my town in South Africa used to apply 1000V on wind up meggers to the nutsack of the unfortunate uncooperative individuals who they had in custody all the time and they were fine...not sure about the reproductive abilities afterwards...
I certainly didn't say that, nor write it!
Just took some time to read the Aphex patent, where they state that the tube's load is a current mirror.
Actually, the topology is very similar to the NPN+PNP variant of the two-transistor preamp.
In order to provide good performance, NFB is required.
I guess if P-type tubes had been available, this circuit would have been used long ago in full vacuum style.
And distortion, thanks to the non-linearity of hFE.It is a current mirror with gain.
That's right!A current mirror does not need a second transistor per se, that is only needed to get accuracy.
...Or, you could use resistive Miller feedback on the second stageIf you use a P-FET with a largeish unbypassed source resistor in the 2nd stage....
You're right ! I admit I was lazy, so I used Google translate. However, my knowledge of written English is relatively good, even spelling is not a problem. For 40 years, I have only read technical literature in English. As a junior engineer, I worked at the Hungarian HT Cooperative for many years, and I got used to it there. (This was the Silicon Valley of "Europe" beyond the Iron Curtain. ) I had a Tektronix oscilloscopes on my desk, just like anywhere else in the world. Now that I'm retired, I have them (TDS224 + MM module) for sound frequency spectrum analysis, a Neutrik A2-D (a very good instrument! )" readout output in distortion mode, where the fundamental harmonic is filtered out, only the "distortion harmonics" fill the screen. Of course, there is also the old analog Tektronix 465, which still works perfectly today, and a LeCroy WaweAce 204. (Color display, USB port, but the "old" Tektronix TDS224 is much better in FFT mode, so I prefer to print it with an old HP Laserjet printer. So thanks for the warning! from now on, I won't be "lazy" and read the original English text!I certainly didn't say that, nor write it!
You may want to check your translator, posting here is (almost) strictly english.
I did exactly the same at exactly the same age. Shot me right across the room. I kept away from TVs from that day on but I quickly got used to 250V HT shocks. Just a tickle.I fixed my neighbors old b&w tv which had a pix tube with a metal cone upon which sat the 15kv anode voltage and I got zapped until I realized the anode was bare metal and was the outside of the CRT. I was about 12 at the time. This was a very early tv set. never saw one like that again.
Not me.Color tv brought bigger screens and crts with all glass construction and 30+KV anode voltage. Even after bleeding them down I still got nailed sometimes due to charge migration. The anode was an inside coating and the outside a sprayed on metallic coating which created a large cap that functioned as a HV filter cap.
Anyone beat 35kv dc?
I remember there were ones that had a vibrator, a kind of mechanical SMPS, to generate a regular HT voltage. Got a belt or two of those.That aside there are some older vacuum tubes made for early car radios that ran on 12 volts as the plate supply. You may want to try and find those for the LV projects. Personally I like 300+ vdc for tube gear. tubes were made for that and sound better, IMHO.
I am not sure what HV voltage a moped ignition coil generates. When I was young and stupid, we actually used to light cigarettes on the ignition spark of our mopeds from time to time. You take the spark plug connector in your hand and generate a spark gap to the spark plug with the engine running. This works, but has minor safety problems. Once I got a nasty electric shock directly on my mouth when lighting the cigarette. I haven't done that since. Learning by pain.Anyone beat 35kv dc?
That would not be NFB-free.
Global or local, NFB is NFB.
