k brown
Scans of my handwritten copies of two Audio Technica mic power modules; the actual schems are not online anymore and I don't have AT spec sheets that contain them. There may be minor errors, but I was just curious to get general overall impressions of comparisons between the two.
One is the circuit inside the AT871R (a very similar one is used in the AT2035), the other is an old external power module, the AT8533, that was used for many models of AT mics. Both were designed for the 2SK660 FET.
The transistors marked 'Q' I was not able to identify (the 871 is all SMD) so don't know the pinouts.
The 871 has what seems to me (my understanding of electronics theory is quite limited) a rather unusual method of biasing the FET, as it needs no DC blocking cap; the AT8533's biasing is quite similar to that in the Shure SM90/91 power modules, but nothing else I'm aware of - FET source has no resistor to ground.
Just wondering if the 871's more complex/complimentary circuit is mostly about increased output current, increased linearity, more sophisticated biasing of the FET, better conditioning of the incoming DC, or some combination thereof.
Thanks for having a look.
