The process was to turn on the unit well away (2M is plenty) from the tape deck with all tapes at least 3M away (we never did it with the tapes in the control room anyway) and bring the tip to the head being demagged and running it back and forth across the surface gradually pulling away while still using the same back and forth motion, repeating this three times then moving to the next head, tape capstain and tape guide posts. This slowly collapsing alternating mag field leaves the heads in a magnetically neutral state.
"running" might not be the best description as it should be a very slow travel across the entire tape path, and since the field is already vibrating at 50/60Hz I never felt the need for me to do any 1Hz "back and forth" funny stuff. Everyone has their own education, I learned from one of Les Paul's techs, and the procedure was verified by mentors along the way. Lets just do it!
Demag a Tascam 52 (clean the path completely first): Plug in 2m away, slow 3-5 sec approach to the left roller, Handi in both hands tongue curve down, butt of hands on the head block, approach roller from above, always maintain a 5mm/.25 inch proximity throughout, slow down-up-over-down the left roller, slow away from roller, slow out .5 m away to move hands, slow approach tongue curved up, hands on the deck to left lifter at bottom, slow up-down, slow past the erase head, slow past the guide, slow past the rec head, slow up-down on the stabilizer, slow up-down on the right lifter (with a Handi I would do stab. and lift. in one shot, with a weaker demag individually), slow past the play head, slow past the tape guide, slow up-down on the pinch roller, same with capstan, away .5m as above to re-position hands on the head block, do the right roller tongue down as above, slowly move Handi away 2m to power down you're done. NgggGUGH! Whew! that was an awesome <3 minutes! You know what "they" say, if you love what you do for a living, you will never work a day in your life.
Remember to clean the tape path again after de-magging. I recommend Athan pinch roller cleaner and pinch rollers when needed. In a "pinch" I use 1 drop of clear dish liquid in 1oz of water. Prefer twill wipes for rubber/urethane cleaning, rolling on a clean piece of paper.
Common sense prevails regarding proximity, keep at least 4m from hard drives/storage, at least 20m from any tape stock or recorded reels, use your "head". No outboard or console issues really.
Mike
