kent
I cut an alligator clip test lead in half and soldered a 2W low ohmage resistor in between. It makes for an easy way to drain large PS caps. On a tube amp I'll stick it between the plate of the first tube and ground so it pulls the current from all the caps through that one point. Just don't forget to take it out when you power up again!
- and that light bulb trick has saved my butt more than once!
cheers,
kent
cheers,
kent
