http://twin-x.com/groupdiy/displayimage.php?pos=-2349
This is the idea I was posting about
Use low side switches to switch in bias change resistor and also the CC or a resistor.
Bias 100K and 220K at 9VDC and with the mosfet on 100K and 110k (220K || 220K)
You can adjust the bias string values etc for what you want.
24VDC turns on the mosfets at about 12VDC at the gate. You could use a LED in the resistor string to show you are running at 24VDC. If you use a tip and sleeve the sleeve will short the mosfet bias resistors to ground making sure they are off. You can find dual mosfets in little dip packages.
EDIT to make things clear
the three S in the circle all connect together
The other two circles has supply written inside, they are connected together
Do you like/understand the auto switching of bias and the CC?
Also I would make the 24V current limited to make sure it does not break when you insert a Tip Ring Sleeve (TRS) plug the 24VDC to ground
Should also have a 100 ohm in series with the output.
