pucho812
since this joke was already done I edited mine out.
Andy Peters said:Hmm, you've never lifted the lead of an SOIC or SSOP device off of the pad, and then tacked a wire to the lead?
JohnRoberts said:PPS: Back in the 80's at one of my businesses we had work stations for stuffing TH PCB that had a foam rubber clamp that would hold the TH components in place when you turned the PCB upside down to solder... It worked well enough for mostly flat PCB.
madswitcher said:Oh and be careful with those hand-hand solder suckers as they are quite viscious and easily lift the track. To make it less so, slide a silicon rubber sleeve over the end of the PTFE sucker head and use it at a slight angle so you suck some air in as well as the solder when triggered. This also saves wear on the PTFE heads.
