Andy Peters said:
moamps said:
I always do connect pin1 to the audio ground,
Which is the wrong place to connect it ... pins 1 go to the CHASSIS.
AES48 is just a recommendation. I'm member there, here is the part:
"An AES standard implies a consensus of those directly and materially affected by its scope and provisions
and is intended as a guide to aid the manufacturer, the consumer, and the general public. The existence of
an AES standard does not in any respect
preclude anyone, whether or not he or she has approved the
document, from manufacturing, marketing, purchasing, or using products, processes, or procedures not in
agreement with the standard."
If you consider that the cable shield is an extension of the chassis, you're getting the right idea.
Nope. I see the shield as a weak link between two racks full of gears in separate rooms.
audio ground to the chassis (power ground) via GND lift switch.
We assume you're not lifting the safety ground ever, but lifting the pins 1 in a properly-wired system makes the shielding less effective.
It is connected to the power ground - chassis on one or both side, so the shielding is fully effective.
I did once wireing for audio part of a one big international TV company using their standard project (about 10000 analog and AES wires in several rooms). The shields was connected only on one side, only in rack grounding bars. I'm not trying to reinvent the wheel here.
