My3gger said:Does anyone really hear difference between SS and tube rectification with preamps runing in class a? Could be difference because of less stiff psu from old schematics.
The load current stays the same in Class A, so a less stiff power supply shouldn't make a difference. With a choice, you may want to use tube rectification because it won't have the following problem.
One thing that does make a difference is the "ordinary" solid-state rectifiers such as 1N4004-1N4007 have a turn-off time after the voltage is reversed, so they conduct for a short time. Once they stop conducting, the voltage is at a strong negative, and the sudden drop in current causes ringing (oscillations around the 100kHz range) due to stray inductance of the transformer resonating with stray capacitance. This can be picked up capacitively/electromagnetically by the audio circuits which rectify them like the radio signal they are, and cause a slight 60Hz buzz (which may make you think you need more shielding).
There are two common fixes. One is to put a snubber across each diode and/or each secondary winding. This consists of a small capacitor (about 0.1uF) in series with a small resistor (maybe 100 ohms). These damp the oscillations. The other is to use fast-recovery rectifiers, which don't have the turn-off problem that regular rectifiers have. If you're a belt-and-suspenders type person, you could do both.
