apzx
Active member
This is an area of transformer theory I am still not 100% clear about but a dc current flowing in the winding will cause a static flux in the core. Because the flux has direction, just like current has direction, this static flux acts like a dc offset so one half of the waveform the core saturates at a lower level than the other half. CJ knows all about this so maybe he will chime in. So I think the current source idea is the way to go. As I said, I am sure I have seen it in the Neve schematics so I would suggest you have a look at how they did it.Thinking on this some more, it really doesn't inherently make sense to apply a DC bias voltage to the transformer. At least to my mind because an inductor should just pass that to ground. Would it not make more sense to actually bias the primary of the transformer with a small DC biasing current from a simple constant current source?
Running a constant current through the transformer should saturate the core more readily, and be easier to control. Unless I am way out in left-field with my thinking here.
Edit - Actually, having done a bit more reading on things (granted in the context of power transformers and such), it seems that applying a DC offset would be the correct action here rather than a current source.
That would be if the total DCr of the circuit was zero. The magnetizing current at DC is the simple result of U/R.The formula for calculating the flux in a transformer from the number of turns, the core size, its material and the applied voltage has a 1/f term which is why transformers saturate more easily at low frequencies. But this means that at zero frequency i.e. dc, the flux would be infinite.
You're making things more complicated than need to.Actually, the magnetizing current isn't that simple (I've done a lot of reading today haha). But it really does boil down to Ohm's Law with some additions namely in the form of non-ideal properties of the inductors in use, and also looks really familiar to the equation for finding the current in a LR series circuit. I did find a derivation for the saturation current that requires knowing the saturation limit of the core material, how long the winding is, the magnetic permeability of the core material, and the number of turns.
A small detail: I'd reconsider S2. The way you designed might cause a short moment of 'no connection' when you flip the switch, leaving the opamp without feedback which might result in a big pop or whatever noise. Maybe always keep R10 and only switch R7 (needs t be recalculated) parallel to it?I have revised my idea a bit based on your suggestions and a bit more thought on my part.
