we want to build an amp with a mellow sounding 5U4 tube rectifier for that compressed sound due to the voltage drop/sag factor.
but we need 5 volts AC instead of 6.3.
a 5U4 draws 3 amps, so to drop 6.3 to 5 we need a resistor that will eat
6.3-5=1.3 volts AC.
1.3 volts at 3 amps, right? so 1.3/3 =0.433 ohms,
Power rating? oh boy, this could be bad, I squared R , 3^2 x .43 = 3.9 watts, so we need a 10 watt resistor to run all day without complaints, forget that, too much heat even if we do find such a weird value, parallel all day long and use up all of our pwr resistors? i don't think so, been there, done that, plus, the glaciers are melting fast enuff as it is,so we want to go green with this project,
plus, we do not know if the pwr trans will have enough backup pwr to run the 5U4's 3 amp heater in addition to the pwr and preamp tubes,
so, we have a 6.3 xfmr looking for a job, why not rewind for 5 volts?
this will provide additional dependability as we have better isolation for directly heated cathodes which will put the heater winding at the same potential as the B+, or the V-ac from the xfmr in the event of an arc over caused by a short or excessive current draw fro the pwr tubes, it is common to use two transformers in Ham Radio circuits where they have higher voltages being used,
here is the basic circuit>
6.3-5=1.3 volts AC.
