Transformer DIY "1st try"
I have already tried to roll some paper caps, but come on, resistors...
Don´t! That´s too much hardcore!
Maybe if you would roll those audiofools silver resistors it would be worth. And I bet it makes a LOT of difference soundwise to use silver resistors... :roll:
But transformers would be nice!
Cool, Steffen & Frank!!!!
Keep this way!
It's up there with Jakob's and IJR's engraving machines
Hehe... those "IJR" :shock: also have their 1:8 micinputs
(done from ripped triad industrial range trafos)
and another tones of hardcore DIY...
BTW, Siemens core Steffen and Frank used are really great.
I had success with smaller ones to make micinputs
200:5k, and they was very nice (+/-1db 15-40k @-2 dbm input and
properly loaded).
Copper foil plays here not last role....
Igor.
[quote author="ijr"]....
properly loaded).
Igor.[/quote]
yes they are :) do you know the alloy they are made of?
I´ve around 40 of them here, from 2 cm core size to 8 cm... "theoretically" we are able to roll everything from micinput to interstage to output xformer ourself ..as said theoretically...
its all a big adventure :) ...and the journey has just begun...
you talking about screening?
steff
I have eight of small size cores, about 1cm^2 inside of bobine
(ugh..my 'inglish!/:-( )
Two of them became my lovely micinput
:shock: tonleitungsubertragers :shock:
( this deutch word is cool!)
They were removed from Siemens test equippment.
They can work up to some hundreds Khz!!!!
(the unit included test oscillator up to 400 Khz).
The iron is VERY good: only 600 turns for ~11H, and
laminations are VERY thick - about 0.1mm.
Great HF response!
Telefunken used sometimes same iron...
And, yes, copper foil for screening between windings.
If your cores have screws on sides , tight 'em good.
After testing of "hardcorediy'ed" :grin:
trafo , put it into hot wax for a minute.
BTW:
hi frequency response is flat up to 300 KHz, peaks around 5dB@436KHz
measurements with 10kOhm load
missed it..
output trannie better to measure with 600 Ohm load...
(just IMHO).
:guinness: :sam: :guinness: :sam:
anybody know of anywhere in the UK that decent cores for audio transformers can be bought?
toby
Congratulations!!!
...as i told in another post,there's an small factory that can build transformers here in my city,today i'm picking a test unit,1:5 to experiment as an input stage...
question:
which is the wire diameter you used? (mm)
thanks!
Maneco,
The wire diameter is the least important parameter...
First you need to know the Al-value of the transformer core - that lets you calculate the needed number of turns to acheive a given primary inductance. This inductance will determine the lowest frequency the transformer will pass at a given source impedance. When you know the number of turns - primary and secondary - you calculate wire diameter from the space given in the coil former (or Transformer bobbin"), taking into account space for insulation layers...
Jakob E.
..i'll start searching for siemens transformer in the flea markets...
Then...paper and calculator :grin:
The biggest that will fit.
Just like the first post of the thread says:
Pick a core that looks big enough.
Wind a few turns and measure the inductance. It is best to measure around 50Hz. Laminated iron-cores do funny things at high frequency, and mostly that is not very important. The important thing is the inductance at the bottom of the audio band.
Inductance increases as the square of the turns. So if 10 turns gives 1 milliHenry, 100 turns is 200mH, 1,000 turns is 10 H. Figure for 20Hz cut-off with your intended source impedance.
For a voltage step-up/down transformer, just figure the secondary turns from the voltage ratio. The inductance and the impedance will automatically be right.
In any practical audio transformer, copper resistance will cause 5% to 20% dead loss. You usually want as little as possible. That means using as much copper as you can fit in the windows of the core.
For a 2-winding transformer, divide the window area in half. That is how much space you have for each winding. You already know the number of turns. Divide the half-window area by the number of turns: that is the area of the wire, including the gaps between round wires, winding slop, and insulation. You will only be able to fill 70% to 50% of the area with round copper. Some test-winding on a stick with wire of an estimated size will help you guess how much copper can really fit.
Oh: estimate the average length of turn of wire. Turns in the middle are shorter than turns around the outside of the winding, get an average.
Now: use the estimated wire size, the resistance per foot/meter of that wire size, and the number of turns, and calculate the copper resistance. If it comes out about 5% of the working impedance (30Ω on a 600Ω winding), you are good. If you started with too many Henries and too many turns, you will have long thin wire and high copper resistance: you should revise your goals and recalculate. If you arrive at a very low copper resistance, you probably miscalculated something.
Windings up to 5KΩ are not that hard to do well.
At 600:600Ω, you can just wind the whole primary, wrap with paper, and wind the whole secondary. The secondary resistance will be higher than the primary resistance; that is not a problem.
Above 1KΩ, you should wind some primary, some secondary, more primary, more secondary. This reduces Leakage Inductance which begins to hurt high frequency performance. A simple P-S-P winding is fine for a few KΩ.
Windings above 10K (as you need for high levels into a tube grid) become tricky: Leakage Inductance is a problem, but so is capacitance. And capacitance gets worse when you inter-layer the windings. Ideally you do a LOT of fancy calculations. As a practical matter: a lot of good transformers use the simple P-S-P layer scheme. Yes, there are trannies with 7-way and 27-way interleaving, but some iron guru must have spent long nights over a hot slide-rule optimizing both the theory and how he would get the winders to do it right.
Also: windings above a few KΩ use VERY fine wire. This may not be readily available except at an audio transformer specialist. Very high impedance windings need wire smaller than US #40, which is already so thin (a fat hair) that it breaks a lot. Also the insulation on the winding is small compared to large wire, but does not get much thinner on thin wire, so the thinnest wires tend to have a lot of varnish for their copper. If the design is going wrong this way, allow more window area for the high-impedance winding.
Siemens is good but not magic. For line output transformer, you actually will be fine with common power transformer iron. CJ proved recently that he can hardly tell the difference between an audio transformer and a "2-4-1"brand 120V:28V 20VA power transformer. And I have used power transformers as mike transformers. Many-Watt output transformers usually are wound very much like power transformers, just more turns and more interleaving. A transformer guru has "better" ways to do it, but with a little care and experimentation I think you can use common power transformer technology. And there are a lot more power-iron re-winders around than audio iron specialists.
There is one kind of ready-made power transformer that is NOT a good audio transformer. Many cores use "E-I stampings", like the one on top of this thread, and both windings are in one lump. The other way uses "U stampings" and has two windings in two lumps on separate legs of the core. It is possible to custom wind a great U-core. But the ordinary power transformer has primary on one leg, secondary on the other leg. This gives good insulation against line-faults, but above a few KHz the magnetic flux from the primary doesn't fully flood the secondary on the other leg. I got about 2KHz cutoff, when a very similar 1-lump transformer was well over 50Hz-15KHz (yes, a small power transformer can have good bandwidth; and I was not optimizing source and load impedances yet).
Cool, folks!
If the things were as simple as you talk!!!!
:grin: :grin: :grin:
I am not trafo guru, but spent some LONG time with guru's and
winders to make my own line input
trafo (and we did it better than J6110 - both
on listening and AP2700 tests!)
Ah, if the things were so simple....
:grin: :grin: :grin: :grin:
Go for OEP's, they sounds better than....my ass!
Thanks PRR!!
i'm collecting all of this information...the most fascinating thing is that one can make experiments...
Well,i picked yesterday the transfo at the factory,did not make any measurement ,except static resistance...it's a 500 turns primary,0,1mm and 2500 secondary...resistance is 66,5 R primary,391 R secondary...the core is e shaped,measures 4 x 4cm,and the width of the core is 1,5 cm...by looking at the windings,it could have been 0,2 mm perfectly,because there's room...
In case this is horribly wrong,could you suggest a power transformer to be used as mic input? (mains here is 220)
I'm happy that i found 12au7 's in a local electronic shop...14,6 dollars each....the guy looked at me as if i was crazy,and said:
"...you came here last week asking for ssop encapsulated pic microcontrollers,because dip was too big,and now tubes ?!! ..."
and i replied,the brilliant quote :
"good sound is not a modern invention" :grin:
Most important - what is the inductance of e.g. the 500turns primary winding The secondary should be 5^2=25times this inductance. This will tell you a very important spec - the Al-value of the core.
And you NEED this spec in order to predict low-frequency behaviour.
Jakob E.
Well,i won´t have acces to an inductance meter until monday...just for fun i wires the transformer as a passive direct box between my computer and my mixer,and ,at least to my ears,i perceive no loses...of course that's not the purpose of the tranny,but i won´t have to throw it away :razz:
oh,no ...wait!...i'm perceiving some bass loss...oh,maybe if i disable the high pass filter switch in this channel it will sound the same as the other channel that i was comparing,without that switch....yes!... :razz: :cool: :? :oops:
well,more seriously,without an inductance meter,i measured the reactance at 50 hz with a 6,3 v ac suply...the value gave 500...
so the inductance is,if i'm not wrong:L = XL / (2 π f) ,so L= 500/ 314
L= 1,59
so AL= 1,59 / (500 x 500) (those are 500 turns...)
AL = 0,00000639
so,if i wanted 5 hy,i should have winded 882 turns...and the secondary should have been 4410...
I don´t know where i'm going ,but i'm learning a lot...thanks!
1600 mH is not horrible.
They are using regular M6 silicon steel since they probably only do pwr applications.
Grain oriented silicon fine for output, but not always input.
Ni better suited for low level, Silicon for high level. (output)
Ask if the have tape wound C core in silicon, .006 inch thick.
Ask them if they have any 49% Nickel. (or, 50/50 as we call it)
You guessed right...they only work in power,but i must tell that they are the best here,when shopping for power transformers,you can see the quality in the aspect of the irons they build ...
I'll ask about different cores,and if i'm not lucky,i'll see what i can make them do using what they have...
Thanks CJ!
