Great thread! I love seeing this kind of organization.
Shouldn't we list the turns ratios/secondary loading conditions for each application to assist in wiring and finding even more substitutes?
Since many people have built them, allow me to add...
Neve Class A preamp (1272, 1290, or 1063/73 minus EQ)
mic input ? Secondary loaded with 4.8k (~5k) yields 1200 input when 1:2 (series:series), or 300 input (parallel:series). Originally made by Marinair, part # T1444, or T1454; and later by St. Ives, part # VT22670.
currently available substitutes:
- Carnhill (who purchased St. Ives) VTB9045
- Sowter 9145
- JLM Audio 1:4 ? Two of them as a series
![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
arallel (1:2) or parallel
arallel (1:4) pair.
- Lundahl LL1538 ? Change cap on the secondary from 180pF to 390pF.
- OEP A262A3E ? Wired for series
arallel (1:3.225).
- or use half of 31267 in reverse for 1:2
line input ? Wire series
arallel (4:1) for 10k input. Neve part # 31267. Originally made by Marinair, part # T1422, T1442, or T1452; and later by St. Ives, part # VT22671.
- Carnhill VTB9046
- Sowter 9165
line output - DC gapped, series:series (1:1.5) for 600 ohm output. Neve part # LO1166. Originally made by Marinair, part # ?, and later by St. Ives, part # VT23326(?).
- Carnhill VTB9049 (original replacement), VTB1148 (narrow for rack mounting), or VTB1847 (PCB version w/breakout leads).
- Sowter 8751 (regular size), or 9160 (narrow version for 1RU cases). Both available with leads or solder tabs.
- JLM Audio 1:1:1DC ? Does not require zobel network of 1.5k & .01uF or 600 ohm load on the secondary. Fits in 1RU with at least 38mm internal height.
- Lynx Audio AT600/600-G
Please correct me if this is: a) too detailed, b) has errors, c) missing any info.
