bcarso
A resistor between the source and common at that point in the circuit for instance---with zero R you drive the gate and get the transconductance times the gate voltage change as a current change at the drain. With the resistor in series the new equivalent transconductance if you will is
1/(1/gm + R);
So if gm (transconductance in amps per volt) is 1mA/V, you get a drain current change of delta V in times that number. Put 1k in series now and yu get half that change for the same gate voltage change, approximately. We assume here that we are operating with the drain voltage well above the pinchoff voltage---say 5V relative to the source, and that the transistor is operating below its ~max current, Idss (the drain current at zero volts gate-source for a JFET, which are always depletion-mode devices unlike your familiar power DMOS devices).
This is an example of local feedback, and usually works to linearize the stage to which it is applied, although there are exceptions ;-).
Brad
PS I will be out of internet access for a bit hence unable to respond for a while.
1/(1/gm + R);
Brad
