Learner
[quote author="PRR"]
And when people throw "600Ω" around, they usually have in mind levels like +4dB VU, which is like +20dBm or 11V peak. Which means 11V/600Ω= 18mA peak. This is HARD WORK for a small vacuum tube. [/quote]
Arhhhh..... I see! :thumb:
I totally neglected that in my plan, thinking that 2Vrms(driving 10K load) was more than enough. Since I've done some listening test on the previous tube circuit I built, by running headphone output on my CD player into the tube amp then to my power amp. I could never turn the output of the headphone to pass 3 on the dial, without getting totally blasted in front of the monitor.
Thank you so much PRR for the explaination!!!!!! :grin: I so needed that!!! :grin: :grin: :thumb:
Now with a clearer picture of where I should be in terms of the spec, I guess what I need to do is to beef up the output a lot more.
I've lower the bias resistor and add an extra tube to spread the current load in the revised schem below, I think I will attempt to build this layout with a 2 x 12A6 Beam tubes, a 4 x 6BA6 tubes circuit and also a 4 x 6SK7 circuit any thoughts/advise on this ?? Too much heat?? :green:
I've also got some 6SN7, 6SL7 and 6AS6(CV4011) and 6AK5W tubes, I think I will use these to build differential and 2 stage RC coupling as pre amp stages. Any thoughts on these tubes as pre amps?
Where can I get these? Are they any different to the Edcor transformers?
:guinness:
Like your plan with the 20K plate resistor: even if I did not know what a 12AU7 was, or had some very good tube to use, the absolute maximum current into the load is 250V/20K= 12.5mA, well short of our 18mA goal (if we ever find that historic 600Ω load). Knowing a little about 12AU7, I doubt you have even 8mA flowing in the plate resistor. If we turn the 12AU7 hard-off, most of that 8mA diverts into a 600Ω load, but that's only 8mA*600Ω= 4.8V pk, 3.4V sine, not even +13dBm. Taking 16dB headroom, we can't crank the VU meter past -3dBm, or the -7VU mark on a meter calibrated for the customary +4dBm at 0 VU.
There ARE good autio interfaces that don't cost a pound of iron. TASCAM -10dB 10K unbal works very well in small studios. Hell, it is how 99% of HiFi playback systems use.
:guinness:
