Transformers "color" box wiring check
fazeka
All,
Need your advice.
I want to have two different types of 1:1 isolation transformers. Was thinking it would be interesting to wire them up with the most flexibility. In series (with differing orders) or alone, with differing secondary impedances. Including a bypass and a polarity switch. Schem is attached here.
What do you think? Do I have this wired up properly?
Chris
  • xfmr_series_parallel.pdf
i built a box like this with 4 transformers per channel with individual bypass and order switchable.
They are highly interactive in a very interesting way. All wired 1:1 to 1:1 without issues
I also installed a couple of rotary switches to modify caps and resistors values (zobel network) right at output connectors
It works like a charm!
I built mine using relays, totally recommended:
https://www.etsy.com/listing/275593012/stereo-insert-switcher-for-mastering-two
Fixed the diagram. I forgot a bridge from one set of poles to connect the output of xfmr B to the output (position 2).
Any thoughts on grounding? I was going to run from the input a shielded cable with the conductors to a ground lift SPST switch and then carry the shield on to the shielded cable towards the output.
  • trans_alone_series.pdf
