Marik
Thank you Dany. I search and evaluate smaller size cores to use in both BV13 and T14. Once I find a good solution I will let you know.
Best, M
Best, M
Marik said:Thank you Dany. I search and evaluate smaller size cores to use in both BV13 and T14. Once I find a good solution I will let you know.
Best, M
I'll add that the C12 with the Samar sounds clean(er), but certainly not sterile.C12 first.
I only listened to the (separate) voice and acoustic samples.
Wow. Yup, the difference is pretty obvious. Samar is much more hifi sounding. It sounds more extended, in any case in the lows (my ears took a serious blow after a hearing accident this year, so I'll refrain from the top treble range) and it sounds cleaner, too. I hear a slight scoop in the mids, but that is to be expected from this type of mic. Esses are fine.
AMI sounds lofi in comparison; more middy (and subjectively trebly maybe) and more grainy. Esses are a bit sibilant. The added midrange could be of use, though.
I do like a little character, but here I prefer the Samar.
