radardoug said:
First you need to realise that the noise level of your Trident is not at -120. It is probably around -70 to -80 below +4. If you had a conventional peice of test gear such as an HP334 this is what it would tell you.
The DAW method looks very pretty, but is quite misleading.
Because it gives you noise vs frequency, the individual noise levels do not show you the summed wideband noise.
Right, a wideband noise measurement is a different thing than looking at a spectrum analyzer. Attached is a screenshot of a noise meter, without any in-the-box boosting from DAW trim plug-ins. Like the other noise samples I've taken, it was captured with the converter's input trim at -10 dBV sensitivity. The noise meter reads -95dB.
Because this noise meter references (digital) 0dBFS, we need to convert its reading to get a measurement with an (analog) +4 dBu reference. To make this translation: a test tone at a +4dBu level, input into the converter set for -10 dBV, produces a -6dB reading on this noise meter. If I'm keeping all my numbers straight, this would mean that the wideband noise reading would actually be -101dB below +4.
This sample was taken from the main mix output of the Trident console, with all channels and groups assigned to the master bus,
but all with muted/faders down, and then the master fader at maximum. So, as I alluded to previously, it is not the true "signal to noise" measurement of the whole system, because all the self-noise from the 36 channels and groups themselves is being muted! What it's really measuring is the noise of the master bus (amplifying the differences between the VE summing amp's ground reference, and the "ground" potentials at 36 different points in the console), plus the self-noise of the summing amps and output drivers.
...And this is why I have not been concerned with proclaiming the noise floor in reference to an absolute level, but instead have been focusing on improvements at each step. In practice, obviously I'm never going to mix on the board with all channels muted! Instead, it has been a way to isolate the noise from the summing bus and summing amps, and improve on those specs... whether or not this goal, in isolation from all other noise sources, is quixotic or not is another question.
Aside from looking "very pretty", I'll say that the spectrum analyzer view has been much more helpful in this process of improvement than the wideband noise meter. I can see things like "oh, that change dropped the 60Hz peak, but the 180Hz peak actually went up".
An Audio Precision meter would be an improvement for certain measurements, I agree. Maybe someday.
