leigh
blake1234 said:Okay, thank you Leigh.
My question about the insert switches in bypass is that even though it's being shunted internally, the insert send/return jacks on the back of the board are still plugged out to the patch bay (which has a normal). The way I've wired the switches, the send signal is always connected to the send jack, I just tapped off of the send's molex pin for the input of the switch. There is electrical continuity from the send all the way to the return via the patch bay. I am concerned about noise from the return line as per this electrical continuity. Are you saying that the internal shunt overrides the snake to the patch bay because it is the shortest path and therefore I needn't worry about the dummy patch cords?
I have one more simple question right now. At the beginning of the forum you say you swapped the summing amps for LME49710's. Are these just IC20 and IC22 on the master section?
So your insert switch bypass isn't a "true bypass"? I'm still not clear on the wiring of the switch, maybe you could sketch a diagram. As I understand it, your insert send is always "split", to both the insert send jack (and thereby to cabling and to your patchbay) and to one lug of the bypass switch. But it's only the return that is actually switched, between either the insert return jack, or the internal molex pin from the send?
About the summing amp chips - yes, IC20 and IC22 are the summing amps. For the purposes of reducing noise, that is the most important pair of opamps to upgrade. However, there are other sonic benefits of better opamps besides just reducing noise, and so I have replaced all the chips in that section.
For example, for the left channel, all these are now LME49710's:
Code:
IC20 summing amp
IC19 insert send driver
IC24 fader buffer
IC16 remix output driver, - leg
IC15 remix output driver, + leg
Haven't seen any oscillations from the upgraded chips.
As an aside, as mentioned elsewhere in the Trident threads, IC15 and IC16 together work as a "cross-coupled output driver" aka EBOS (Electronically Balanced Output Stage). For various reasons, the circuit is kind of crappy (for one, it's unstable, which is why they added those 12k resistors on the output jacks between each output leg and ground), and ideally it would be replaced with a better output driver circuit.
