I think a good idea to link aswell the link a pic of the original shem by Samuel Groner.
I have built it. For some reason, an oscillation tone appeared when there was no load at the input. I solved it, using a switching jack, and making a shorting input. When plug the jack, the input gets unshorting.
The oscillation came from a non-optimal layout design, and a posible capacitive coupling between in and out. Samuel gived me some guidelines for avoiding the problem. I will not rebuild mine, but probably could be useful for any of you if you are planning to build it, to avoid posible oscillation problems.
[quote author="Samuel Groner"]The input is a very high impedance node when left open and any capacitive coupling to the output might provoke oscillation. The easiest fix would be to just use a shorting input jack. Otherwise you can play with the layout--distance from input to output helps. In addition to this, you might want to use shielded cable from the jack to the opamp input. [...]
* R1-R3, C1, C2, D1, D2 close to the noninverting opamp input, cable from jack to R1 shielded (shield grounded)
* R4, R5, C3 close to the inverting opamp input
* The wires for R6, C4 routed away from the output and noninverting input, perhaps even shielded (shield grounded)
* R7, R8, C5 close to the other opamp inverting input
The rest should not be critical in placement. If nothing helps, you could try increasing C3 and C5 (say to 220 pF and 100 pF maximum), but this should not actually be necessary. It's really a question of layout I'd say. [/quote]
