I started to do the detail testing recently with these, after using them for a few months ..
On the bad side :
- I have a 100Hz hum at more dB than I care for - it's just audible in use, which is quite a bit too high
It appears to be ripple on the supply B+ at the input tube. Not dependant on volume setting.
Messing about now to reduce it.
- the input tube, Phillips Jan Nos 5687 is very microphonic - it pings like a pure and pristine little bell when tapped, quite loud.
Subbing a 12B4A tube instead, running at around 150V plate and 20mA.
Hopefully I can find one with less microphonics
On the good side :
- the dc voltages all track very well with what I calculated
- the gain staging thru the amps all track very well with what I calculated
On the very good side :
- no oscillations at all, even at full output of 32Wrms with no visually detectable distortion 1KHz sine wave
- the frequency response is amazing : at around 10Wrms output into an 8ohm load box
-1.5dB at 20Hz and -1.5db at 20KHz with 3dB points at something like 10hz-30Khz
ruler flat
I haven't done any feedback compensation yet - just a single 15K resistance from 8ohm tap to cathode divider at input
That Edcor output traffo paired with the Jensen at the input is a great combo, especially considering the price.
Still very happy with the sound. I actually swapped speakers to some cheap but good sounding dual 15"+mid+high units. I paid f* all for these but they are actually pretty good. Being so large and powerful, they have high senstivity and do the bottom extension of the amp justice. Running at modest levels, they sound relaxed and full.
I have finished reorganising my test kit - a high powered load box with a feed to the audio analyzer and an upgraded 96KHz audio interface as well capacitance and resistance substitution boxes.
Once I sort out the hum and microphonics, I will start auditioning the feedback network and do the next level of detail testing.
