Don't want to be misunderstood, wanted to say, right tool for the right job.
I built myself over 10 tube amplifiers - for me and customers. EL34, KT66 PP, 300B SE.
Used Tomura and Hashimoto outs; than, trannies were homebrewed - for inputs I have good stock of Magmet laminations,
outputs/chokes/power trannies were done by my friend, who is still freak of tube amps.
There is a local company Eilor which makes custom rolled cores, their Hi-B is best iron for output trannies IMO.
I still have respect for tube amps when want to relax with a glass of good poison like Laphroaig or Oban,
listening Diana Krall or Ella Fitzgerald. Or Echoes. Audible distortion sometimes is good.
From the other side, for monitoring, I don't think any tube amp will piss out fast discrete transistor class A, inherently linear,
with about 20db feedback amount, design for mids/highs, plus Class D for subs.
For something like Tribal Tech or Pat Metheny Secret Story, or Porcupine Tree, I don't like to hear any colour in sound,
as well as for mixes or mastering - why should I listen to "good" sound, when it will not sound same outside?
More older I get, I want to listen clean. When I'll have a good deal for wall ATC oldies, this will be my next project for home,
and every bit from crossover till power amps will be another challenge.
BTW, only 4 high current pairs of relay contacts for load and 2 pairs for input, measurement mic,
1kHz signal and a person to switch amplifiers without telling you which is which needed to get your own decision.
Take your amps, and say medium range Hypex, equalize levels for +/-0.1 db, blind a/b, and write down a table of what you feel on different music.
The truth is in between. More people, more opinions. Dats good, agree.
Norwegian black? No way. Bad children.
Yes, sometimes I used to listen when I work at workshop very heavy stuff - like Carcass and Napalm Death, but
it is more state of mind than a music. Very bad recorded, though. Yes and Genesis are in my playlist too
BTW, you may try to make your amp completely balanced... CCA at the input and 1:1+1 good trannie, cross coupled feedback to both cathodes.
Output trannie in this case should be symmetric too, even worthy to try feedback through tertiary.
Anyway, just my $0.25. If tube amps for monitoring is the thing makes you happy, call me freak, same for you, hanshake and respect!
Interesting... Sansui SP2500.... May sound great for home, but.... Can you really hear the difference between MP3 320 and 16/44 with this setup on blind equal level test?
