Melodeath00 said:
I feel I am so confused.
If I wanted to increase the plate voltage to reach a more "vertical slope" portion of the curves (and thus, lower output impedance), how would I do it? Lowering the 150kohm would change the load line, and place the bias point "further up" into the more vertical portions?
Could I keep the 150kohm the same, but change the cathode to 2V? Would that raise the plate voltage at idle? It seems like it would, but maybe it would also increase output impedance do to the slope of the -2V grid.
Again, not sure I'm grasping this at all, unfortunately.
You are close: lowering the plate resistance reduces output impedance. If you keep the B+ the same, this reduces the slope of the line and makes it "flatter". Quiescent current will drop, so there is less delta change in current for a given change in grid voltage (e.g., gain is less).
Changing the cathode to grid voltage via a cathode resistance changes where along the curve the tube sits a "idle", or 0V grid input (wrt. ground). If you want it to idle farther up the load line, you must increase the cathode resistance. You would plot you load line, then start at 50V at the bottom of the tube curve chart (50V/0mA point), and go "up" until you hit the load line. You then estimate the grid voltage at that point (VGQ), then follow that point directly left until you intersect the vertical axis and find the current at that point (IQ). The cathode resistance is then just VGQ/IQ.
Your tube and the tube curve aren't the same: the actual points might be different. You could start with a 10K pot at the cathode, then dial it downward until you read 50V on the plate (remembering that 50V is the plate-to-cathode potential, not plate to ground potential). Then read the cathode voltage and that will give you the grid bias that gives you the 50V plate-to-cathode level (could be -1.5V, maybe -2V? Hard to say).
This explains it pretty well:
http://www.angelfire.com/planet/funwithtransistors/Book_CHAP-4A.html
This pic is from a JFET, but it shows the same principles (load line, Q point, input on gate/grid, output on drain/plate):
Hopefully this helps!
