You could use a listed 12VAC wall wart to power the box with the other transformer in the box that MIGHT be good enough for code you would need to check.OK, so you mean it would be mains powered?
I would much rather have an iec mains lead plug into the box, even if the box were considerably bigger as a result. I did exactly that when I made a sanasamp bass driver copy.That's OK but I have to ask, what would you like? Surely not a mains cable either so are you asking for it to be battery powered?
I did mention using an AC wall wart but I think someone said they are not readily available any more.You could use a listed 12VAC wall wart to power the box with the other transformer in the box that MIGHT be good enough for code you would need to check.
Which 150H choke do you mean?Whats the resistance of that 150H choke?
Broskie is still using them, I find it hard to believe they've gone the way of the Dodo yet?I did mention using an AC wall wart but I think someone said they are not readily available any more.
IAn
They are still available from Farnell and on Amazon and the Broskie power supply is exactly what I had in mind.Broskie is still using them, I find it hard to believe they've gone the way of the Dodo yet?
https://tubecad.com/2020/06/blog0505.htm
I quite like the idea of a battery powered unit. Possibly use a DL92 (1.4V @100mA heater) along with SMPS HT supply of say 48V? With just 3mA at 48V the switcher would require another 100mA at 1.5V. A C size cell at 100mA discharge has a 6000mA/hr capacity so it would last 30 hours. Is that long enough? The DL92 can be used with its heaters in series at half the current. This would also simplify the SMPS and halve it current draw giving something like 60 hours life.
For some reason 12VAC outputs are much more common than 9VAC.Just did a quick check and..... damn, what happened ?
These are indeed very hard to find now.
I would not be too hard to make it rechargeable (from a regular stomp box 9VDC supply). C size Nickel Metal Hydride batter C cell at 6000mAHries are about £6. A pair would give a raw dc supply of 2.4V. THis might be a little low for the DL92 which is specified for 2.8V (series heaters) but still worth investigating. Only 4500mAHr compared to an alkaline primary at 6000mAHr so life would be shorter but it should still easily last 24 hours.This could be the way forward Ian as I suppose there are plenty of other mains powered valve DI’s one could make, so having something a bit different would make it a more unique project.
No, its a complete switcher PSU (minus transformer) for B+ and heater voltage.So the board you are moving around is a PSU filter ? some caps and chokes ?
The output voltages are pretty clean, with little additional filtering absolutely useable. Ruud used this board for an U67!At the output of that board the hash is probably gone, filtered, but it is still at the input jack and the cable.
Yes, that's clear. It's a test setup for now. If in doubt, I will shield the entire PSU. Distance is also your friend when setting up a amp like this...Also the wood does not provide a lot of sheilding...
