Starting this thread for Tube OTL and Zotl amps. I asked for A and D power amp forums. Until we get one this will have to do.
Zotl is not Class D (only if you want it to be). Please read the patent.ZOTL? Why not just make a Class D Amp with a Tube in the first stage?
https://davidberning.com/technology/patent5612646
The HV ac power supply is polarized but not filtered (using diode bridges). In this case the tubes do get almost 100% pos voltage (with a small gap because of the transition. This can be overcome by using 2 square waves overlapping each other (Quadrature). In this case the tubes get 100% DC on their anode if well executed.
With Class D amps you will need a filter on the output of the amp, with Quadrature Zotl not.
This because of the push pull nature of it will nullify the transitions on the output node (what is left over from it as there shouldn't be any in the first place) .
Because it's not as good. There are some of those around. It works but it won't sound like a Futterman OTL especially in the top 3 octaves. I have yet to hear an amp that sounds as good as a FOTL. Not even my Moscode tweaked to the max.Hi,
For "OTL Tube Amp" I would probably just do a Futterman style Amp using a sensible output tube that can drive 600 Ohm (maybe a few 6N30 in Parallel) and add P-Channel Mosfets in a compound feedback pair to drive low impedance loads.
Yes, it's not strictly "OTL Tube" BUT is will give really high power and sound very much like a tube OTL Amp.
Thor
That's true for every forum I've been on. Motorcycles, cars, audio, etc. But at least here there are some pros despite the fact there is a real distinction between the pro audio and the Hi End consumer audio audience. Peavy, Fender and every other guitar amp is not high end audio by any means. 95% of Pro audio just has to work good enough, it doesn't have to let you see God. There are audiophile record labels that do care but it isn't a big market. Maybe it's time for a new thread about this.I use adjustable feedback so you can set your sweetspot depending on loudspeaker used. So even no feedback is possible if you like ( some purists insist of having none).
Funny how most think they understand how things suppposed to work but never had hands-on experience.
I am not talking about this topic here just in general .
Like telling someone how to drive a car without having driven themselves ever.
Best regards,
Frank
