babisbabis
Member
Hi all!
I am Babis from Greece.
A little of history first, I'll try to be short:
I have a friend's Tube-tech MEC1A (Lydcraft) for repair. In fact he gave it to me for adjustment.
But I realized that something is wrong with it, when I noticed (adjusting it of course) that the "gain trimmer" was at the "minimum gain".
Anyway, it seems to me that the final stage with tube ECC82 doesn't work as it should. The output isn't stable. For example, if you input a sinewave signal of -20dbu (like the adjustment procedure recommends) and you set the output gain potentiometer for an output of +4dbu (0vu on most vu-meters), after a while it varies between +/-2db...
I've measured the psu voltages of course. The 12VDC Test Point for 12VDC (heaters) gives me 11.2VDC (?). +/-150VDC is ok (adjustable), 240VDC is ok (adjustable), and 270VDC behaves a little strange... I remember my first measurement was about 256VDC. I noticed that it's not stabilized. Yesterday I measured it 270VDC. The tube (ECC82) was in its base. I saw from the PCB that these 270VDC, are for the ECC82's anode(s) only (via the output transformer).
Well, the 2 resistors that I mention in the title, R201 & R202 are on this rail of the 270VDC. Someone has replaced them and I guess he/she has replaced them with other values than the original ones. I suppose so, because he/she has written their values on the PCB. R201 is 1.5k 5W (or 3W), and R202 is 470R 5W (or 3W).
Anyone knows what is the right value for these resistors?
I wish I had the schematic, but I guess this is from difficult to impossible...
I've found here the schematic of LCA-2B in which the PSU section for the 270VDC is very similar to the MEC1A's. I've included an image with this part of the schematic with the few differences.
*Without the ECC82 on it's base, the "270VDC" measures about 320VDC (i.e. without load) if I remember well. Ok, this is unstabilized voltage, rectified and filtered with two 100uF capacitors (through 2 resistors). But isn't it a high voltage for this tube? Just a question...
*The ECC82 turns really hot. The other 6 tubes have considerably lower temperature. Maybe this is normal, I dont know...
*I am afraid that maybe the output transformer could be suspect too...
*And of course the question of the title: What is the real value of R201 & R202? If someone knows, I'de be glad.
I tried to be short, but I think I didn't manage to...
Sorry for the big post, any help welcome!
