Kingston
Also, mixing and smoking weed is a really bad and unprofessional idea so I'm really beginning to doubt this "chief" of yours. Of course everything sounds like magic under the influence.
But isn't everything more or less subtle?
Kingston said:Also, mixing and smoking weed is a really bad and unprofessional idea so I'm really beginning to doubt this "chief" of yours. Of course everything sounds like magic under the influence.
e.oelberg said:Kingston said:Also, mixing and smoking weed is a really bad and unprofessional idea so I'm really beginning to doubt this "chief" of yours. Of course everything sounds like magic under the influence.
most of dub music has been mixed completely stoned, it sounds fantastic !
riggler said:Could hear it recording my dad playing banjo night and day.
Kingston said:riggler said:Could hear it recording my dad playing banjo night and day.
And yet, it was not night and day, apart from the difference of weight in your wallet. Most people on this forum would not be able to hear the difference, let alone measure it.
Kingston said:Night and day is -3dB at 10khz or a sudden loss of all frequencies below 80hz.
JohnRoberts said:Whether the difference sounds as dramatic as you describe could be influenced by what you were smoking during that break and how bad the old tubes were.
Kingston said:Heck, most people with G9's never even noticed the total lack of bass (something like 3-5dB cut at 50hz) due to LL5402 always being mismatched to the output stage. And that one at least could be easily measured!
gyraf said:Kingston said:Heck, most people with G9's never even noticed the total lack of bass (something like 3-5dB cut at 50hz) due to LL5402 always being mismatched to the output stage. And that one at least could be easily measured!
Just checked my standard G9/DIY (with Lundahl in and out). I have -3dB at 29Hz when run from a 600 ohm source.
So you may want to check your setup - specially the value of the (4u7) output capacitors, as bigger isn't better in this case!
Jakob E.
emrr said:As much tube gear as I have, and use, and as many different samples of various tube types as I've listened to, for as many years as I've done this.......
I still can't imagine thinking during a session "I should change a tube type in that piece, for better sound". Doing so certainly paints one as a wizard, and further ahead of everyone else in the room. Nice piece of political theater.
