Turning a Sennheiser MKE10 into a PZM
Thanks all
Yes, I can derive the measurements from both those figures.
I searched for the research paper you referenced but couldn't find anything.
Can you share a link to it please.
I'd like to understand more of what their analyses showed.
Here's the Neumann AES paper.
At one point I actually made my own SASS-B type mic using the spiral boundaries. Unfortunately it looked like a couple of huge pinnae.
  • GFM research AES paper.PDF
    601.7 KB
Thanks so much for the paper. It has some very pertinent information.
From reading it, I see now that a larger 1,2m x 1,2m plate is not good.
I think I'll start with the GFM triangle made out of MDF or Hardboard .
Later try a spiral version.
I would have liked to see some more discussion of how they 'calculated' the dimension needed for the triangle and spiral.
They discuss the minimum size needed for half wave length of the lowest frequency desired. But that is for regular shaped object.
Perhaps for an irregular shaped plate (GFM Triangle or Spiral), you would use the maximum distance across the plate passing through the center of the microphone to calculate the lowest frequency.
This'll give you all the deets on boundary sizes regarding shelf frequencies, and much more.
  • boundary mics study_Crown.pdf
    1.2 MB
  • Crown application guide.pdf
    1.4 MB
    601.7 KB
Not quite sure what you're asking, but perhaps the Neumann GFM research paper will help.
Thank you for your response. I read the paper, but I can't figure out the dimensions. I'm guessing 13 mm is the thickness, 213 mm would be the base but what is 168mm ? Do we need to know one of the angles ? What is the position of the microphone ?
The dimensions I gave are from the user manual, attached below.
(If you can make the effort, doing the spiral is the ideal shape. The whole idea is that every point along the edge is a different distance from the capsule, so edge diffraction effects don't 'add up'. The triangle is a compromise to manufacturing practicality; because of the straight sides, there will be two of each dimension from the capsule to that edge; not true of the spiral.
I made spirals from 1/4" hardboard using a coping saw, and filing/sanding the bevel on the edge; then gave them a paste wax finish. Not perfect, but better than the triangle.)
Safe to assume that 213mm is the longest side; Logical that 168mm is the distance from the long side to the 'point' opposite it; you can pretty accurately infer the other dimensions/angles from this illustration in the AES paper (note that none of the angles is 90 degrees):
    35.1 KB
  • GFM 132 Microphone User Manual.pdf
    663.7 KB
