Hi all,
I'm looking to make two p2p pultecs based on this design and layout
http://www.recproaudio.com/diy_pro_audio/pultec_eqp1a.htm
I have sowter signal level transformers and am now pondering what to do with power. I wanted to go with the 370CAX, but the site says:
The shop where I wanted to buy it from (http://www.tube-town.net/ttstore/product_info.php/info/p1014_Hammond-370CAX.html) lists the heaters as being CT. Just to be on the safe side, is this power transformer appropriate?
Second, I wanted to modify this pultec design to have a switchable high pass filter (no need for steep curves here). How would one go about designing this feature? I have talked with an EE friend of mine and he said that it's hard to predict how the circuit will react, so it would be best to build the rest in its entirety and test it, then add on the HPF by experimenting with values.
Is this truly the best way to go about it? Can't I precalculate the filter R/C values?
Update: It has been brought to my attention that the Hammond 270CAX power transformer is no longer made with a center tap for the 6.3V winding. To accurately float the heaters, you will need a transformer with a 6.3VCT. Earlier 270CAX transformers with 6.3VCT might still be available from some sources such as Angela Instruments. Sowter also has the proper iron.
