I have been in the process of designing some 32C cut filters for some time. My motivation was out of the need to have some quality analog cut filters for tracking or live mixing. Other available circuits having hard to source parts or limited functionality. I have two versions. A variable card that will fit 8 channels into single 1ru case featuring true bypass, LPF bypass, LED visual feedback, THAT 1206 input, THAT 1646 Output, and a separate 3-rail power supply. Then I was thinking I needed fixed cut filters for stereo channels or for repeatable cuts, so I loaded up LTspice and found the resistances needed for the desired cuts. This unit is in 500 series format with grayhill switches.
500 Series Type 32C Switch Filters Front Silkscreen.jpg574.2 KB · Views: 1
