nielsk
Working on a U-47 converted to EF-14, all other voltages look pretty close but to get the voltage at the node of G2, G3, A (1,4 &5) & the output transformer close to 34 volts, I have to change the R1 100k resistor to 250k (B+ is 105 VDC).
It is right at 1.1 VDC at pin K (7)
Is this a problem, or is getting the voltage correct the most important thing?
